Thank you for your feedback.
Audirvana Studio 2.2.5 (20205)
macOS 13.2.1 with 8GB physical RAM
Connected account of : (name)
AUTO: /Users/username/Documents/Bibliothèque locale Audirvana
Library database path: /Users/username/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 57375
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
AudioQuest AudioQuest DragonFly Cobalt v1.0
Model UID:AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID:AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0101020123:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 6 bytes per frame 88.2kHz
Active Sample Rate: 88.2kHz
Hog Mode is on
Selected device:AudioQuest DragonFly Cobalt v1.0
Manufacturer: AudioQuest
Model name: AudioQuest DragonFly Cobalt v1.0
Model UID: AudioQuest DragonFly Cobalt v1.0:21B4:0085
UID: AppleUSBAudioEngine:AudioQuest:AudioQuest DragonFly Cobalt v1.0:AQDFCB0101020123:1
USB Vendor ID: 0x21b4
USB Product ID: 0x0085
ID 0x50
MQA Renderer device
Stream ID 0x51 2 channels starting at 1
8 virtual formats:
8 physical formats
Device #0: ID 0x50 AudioQuest DragonFly Cobalt v1.0
Device #1: ID 0x44 Haut-parleurs MacBook Pro
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Haut-parleurs MacBook Pro
