SysOptimizer error Studio
Good morning all,
Since switching to Studio, i have an error 4 on sysoptimizer is this normal? can we correct this?
Same issue, same error, for me under macOS, Big Sur 11.3.1.
Yes, under macOS Big Sur
Logically, until this issue is not solved, we are unable to have an educated judgement on sound quality of the app, because SysOptimizer is supposed to improve it.
Exactly, It maybe an audirvana or software error on mac
Hello @Joffrey and @Doudou,
When you first started a track in Audirvana studio with Sysopt, did you get a window from MacOS?
If I stop the playback and launch a new track, I get immediately the window “Installation nĂ©cessaire” of SysOp. I allow the app to install SysOp and provide my password. But right after that I get an error 4 message, telling me SysOp could not fully install.
It happens each time I try to play a track after the playback was stopped.
I get the same as Doudou
Enable sysop and click restart all services I get this error
and then after choosing to install and entering my password I get this error
Exactly the same indeed, but in French. After that, the track plays but without SysOp optimization.
and also
Apple hide the Home Folder in User Library at some time depending on OS System
just do a ‘‘cmd J’’ to show the folder settings preferences and see at the bottom
Close Audirvana.
Go to the Main Library Folder
 PrivilegedHelperTools folder
 LaunchDaemons Folder
Restart Mac and Audirvana and see if it installs now.
I don’t have either of those sub folders in my Mac Library folder.
me too
:unamused: I don’t have this folders.
Damien told in another thread to do those 3 commands in terminal
sudo launchctl load -w /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
sudo rm /Library/PrivilegedHelperTools/com.audirvana.SysOptimizerTool
sudo rm /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
No such file or directory :pensive:
Same here Damien on 2 different configurations: Mac-mini / High Sierra, and PowerBook Pro / Big Sur. I have checked the directories, the files are not in .
Alain
I just checked my A+ 3.5 on an other Mac-mini, the files are in the right directories. That means that for some reason Studio cannot install these files
can you try to copy them to the same place on the mac sysopt not install
I don’t have any “PrivilegedHelperTools” folder in my library.
I have Audirvana folder inside “Application Support” folder, but there’s no “PrivilegedHelperTools” there.
So what should I do?
Yes I can do that. Just need to change “Audirvana-Plus”, by “Audirvana”. Let you know after dinner :wink:
