@PML, @Mathieu, @Doudou
Celui que je n’oublierai jamais c’est le PowerBook G3. Une machine tout terrain indestructible qui m’a suivi sur les chantiers très, très longtemps…
Don’t worry he pays me in very nice food whenever I come by
Here is what you need to do:
Launch a terminal then go to the first folder:
cd /Library/LaunchDaemons/
Change ownership, permission and remove quarantine of the Audirvana files you have installed there (sudo command will ask for your password the first time)
sudo chown root:wheel com.audirvana*
sudo chmod 644 com.audirvana*
sudo xattr -d com.apple.quarantine com.audirvana*
Then go to:
cd /Library/PrivilegedHelperTools/
Same here if you have the files:
Then reload the daemon process with:
sudo launchctl load -w /Library/LaunchDaemons/com.audirvana.SysOptimizerTool.plist
You should be all set (you can if you want then run the 2 other commands from Damien but they are not necessary to make it work).
Free for dad of course, I’ll send the humongous invoice to Damien, expect the subscription price to double due to the consulting effort
En plus, quand je lance vos commandes dans le terminal, le terminal me demande mon mot de passe.
Et quand je tape mon mot de passe d’administrateur, il le rejette !
Je ne comprends pas… Est-ce qu’il faut taper dans le terminal le mot de passe d’installation de l’application Audirvana Studio ?
