System optimizer
Why am I getting this now. Haven’t upgraded to a point .27 or .28 Because everything was working OK not great but OK.
Damien can you help me out here
try deleting is preferences…
Close Audirvana
Restart MAC. Restart Audirvana…
Thx :blush::+1::+1::+1: will give it a shot
The SysOptimizer installation error message tells another application had created a security hole by setting the wrong permissions for this PriviledgedHelperTools folder.
To fix this permission issue, you can use the Terminal application and enter the following commands:
sudo chgrp wheel /Library/PrivilegedHelperTools
sudo chmod 1755 /Library/PrivilegedHelperTools
All I did was restart my computer everything is fine now. I did not understand what you were telling me to do with the latter comment you had sent me. Now it seems like I have a problem with Qobuz loading through Audirvana Remote… I go to the app“ Qobuz app everything is just fine. So to me this has something to do with the Audirvana ® remote app. Also the remote is very sluggish and slow and I am on the latest version. Once again I think Audirvana is the best sounding software I’ve ever heard. And I have tried them all.
Also last week I could not get him MQA titles to play and now they play fine no problem. And I have not updated to the latest to software offers from a Audirvana because I’m scared they’re going to introduce glitches because they are for Catalina. Now this week I have the Qobuz problem.Im just at a lose of what to do. Also navigating the Qobuz app and getting some help has been very disappointing. So I thought I would send a direct email to Sebastian and I have not heard from him which is again very disappointing. I also think that should be a concern of you since you’re implementing Qobuz through your fabulous music software.
this is what im getting … i tried deleting files that were in my PrivilegedHelperTools folder LaunchDaemons Folder, that didn’t work… then tried terminal commands , again no joy. even deleted the whole program and did a new install with no success .
this what i keep getting as the error message;
There was an error executing SysOptimizer. Not all optimizations may be done.
Error = The operation couldn’t be completed. (CFErrorDomainLaunchd error 9.)
You tried everything i wrote in order ?
yes i did and still didn’t work
So after the restart when trying to play a song Audirvana tried to reinstall sys opt ?
with every song, album, and playback device
I know it doesn’t work, but after deleting the files and restarting the computer. Opening audirvana for playing a song at first, it duppose to tell you that it needs to install sys opt…
Did it ask?
and i keep getting the same error message each time. it get it to play i have to shut off sysop and just let it play back in the normal format.
first to be reinstalled it has to be open in Audirvana i think…
so, put it all like me in my picture here…
then close Audirvana
Restart MAC.
Restart Audirvana
it should ask to reinstall it upon trying to play the first song… say yes :slight_smile:
