Hello, I am seeing this issue since yesterday, albums I was able to play previously, I can no more. Please find the debug info:
Registered to
Sync list: 0 folders
Library database path: /Users/aprasanna/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Schiit USB Audio Gen 2
Model UID:Schiit USB Audio Gen 2:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14210000:1
Active Sample Rate: 48kHz
ID 0x2b Schiit USB Audio Gen 2 Manufacturer:Schiit Audio
Model UID:Schiit USB Audio Gen 2:0D8C:0004 UID:AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14210000:1
Stream ID 0x2c 2 channels starting at 1
24 virtual formats:
36 physical formats
Local devices found : 3
Device #0: ID 0x5a DELL U3417W Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:30001:0:{AC10-A0DF-3036334C}
Device #1: ID 0x2b Schiit USB Audio Gen 2 Manufacturer: Schiit Audio Model UID: Schiit USB Audio Gen 2:0D8C:0004 UID: AppleUSBAudioEngine:Schiit Audio:Schiit USB Audio Gen 2:14210000:1
Device #2: ID 0x4e MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
