Audirvāna for LINUX and NAS (QNAP/Synology) officially released
Exactly that I was looking for !
Thanks a lot !
For any users looking to run Audirvana in a Docker container on an existing desktop host and wish to use the host Avahi daemon and mDNS services, I’ve tested this on Arch Linux based Endeavour OS:
# Use the latest Ubuntu LTS as base image
FROM ubuntu:22.04
# Avoid user interaction with tzdata
ENV DEBIAN_FRONTEND=noninteractive
# Update and install necessary packages
RUN apt-get update && \
    apt-get install -y --no-install-recommends \
    gdebi-core
# Copy the Audirvana Studio deb package into the container
COPY audirvana-studio_2.8.1.1_amd64.deb /tmp/audirvana-studio_2.8.1.1_amd64.deb
# Install the Audirvana Studio deb package along with its dependencies
RUN gdebi -n /tmp/audirvana-studio_2.8.1.1_amd64.deb
# Clean up
RUN apt-get clean && rm -rf /var/lib/apt/lists/*
# Modify nsswitch.conf
RUN sed -i 's/hosts: files dns/hosts: files mdns4_minimal [NOTFOUND=return] dns mdns4/g' /etc/nsswitch.conf
# Set up the entrypoint to start Avahi daemon and then Audirvana Studio
## Commenting out as I'm using the host avahi daemon
#ENTRYPOINT ["sh", "-c", "service avahi-daemon start && /opt/audirvana/studio/audirvanaStudio"]
# Set up the entrypoint to run Audirvana Studio
ENTRYPOINT ["/opt/audirvana/studio/audirvanaStudio"]
The command that you can run, which will also save Audirvana configs in a Docker named volume (so you can remove and recreate the container), is:
docker run --rm -d --network host --privileged --device /dev/snd -v audirvana-configs:/root/.config -v /var/run/dbus:/var/run/dbus --name "audirvana-studio" audirvana-studio
Docker Compose
The equivalent docker-compose.yml file would be structured as follows, automatic restart with Docker daemon on boot is configured via restart (I haven’t tested this):
yaml
services:
  audirvana-studio:
    image: audirvana-studio
    container_name: "audirvana-studio"
    network_mode: host
    privileged: true
    devices:
      - /dev/snd
    volumes:
      - audirvana-configs:/root/.config
      - /var/run/dbus:/var/run/dbus
    restart: "unless-stopped"
volumes:
  audirvana-configs:
docker-compose command to start
docker-compose up -d
While in the directory with docker-compose.yml
docker-compose command to stop
docker-compose down
Update: I’ve tested this now, and it seems to work.
Update 2: Your mileage may vary with the docker-compose version. Some odd issues causing the app to crash.
Update 3: Complete removal / re-install of the Remote app seems to have corrected this. Docker-compose version running well.
Issues noted:
1.) Settings menu in the Remote app for Audirvana has a lot of poorly rendered popups on Android and strange titles in the Settings page in app. E.g., titles like “SETTINGSAUDIOOUTPUTDEVICETITLE”. It’s usable, but very “beta”.
2.) Audio playback progress bar not incrementing while track is playing. Play/Pause works though, so it is usable.
3.) “Unlock Device” does not release my iFi Zen DAC v2 from ALSA. Stopping the container releases it, obviously.
4.) When upsampling is enabled, playback progress bar increments correctly.
Re playback progress bar incrementing, see UI bug on Debian
Do you use the Raspberry Pi Linux distribution, or did you choose another? I have a Pi with 2Gb and would like to try, but I’m not a Linux expert .
Hi
I used the standard Raspian distribution as I thought it might be easiest. Audirvana seems to run fine in 2 gig at original sampling rates.
Not sure if this is an Audirvana bug, or something else.
My 2 gig Pi 4 works well over USB at any incoming sampling rates. I have a Pi2AES HAT which uses the same driver as the HiFiBerry Digital Pro +. If I edit the appropriate ;one into config.txt it works fine fore sources ar 44100/16 bit, but for any other incoming rate, even 44100/24 I just get static.
Can anyone recommend how to install this on a 10i7NUC? I currently run Euphony on it. I also have a QNAP NAS so perhaps I should run that first on the QNAP NAS and then compare both… I’ve been an Audirvana user since version 2 and always loved the sound quality.
I have made a package for Archlinux (without using debtap).
avahi daemon socket is enabled. To be sure I have also enabled avahi-daemon service.
However if I start audirvana I have always this message:
2024-04-14 15:06:10.172 [info]:         =============  Started Logging, Audirvana Studio 2.8.1.1 linux  =============
2024-04-14 15:06:10.173 [info]: EULA not accepted yet, showing it
How can I accept EULA?
That’s the message I get when avahi-daemon isn’t running. In your case, could it be a firewall interfering with communication?
I don’t think so. All other audio services are working, including Roonserver and HQplayer with UPnP.
I must open some port?
I know 1% of the Linux you know, if that. :slightly_smiling_face: But when Audirvāna is working, I do get a message the server is communicating on a port number, but IIRC the port used is not necessarily consistent.
The EULA is accepted when you attach the remote app to Audirvana and is recorded in an INI file in $HOME/.config/audirvana/. You could also set it to accepted by editing the INI config. I’m not near a computer, so don’t recall the file name or the exact variable. Hope that helps.
Apologies but Linux isn’t my forte.
In fact, installing it on my NUC as a dual-boot with Win11 almost buggered the PC completely :scream: :rofl: :rofl:
What exactly do I need to do with this file to enable Studio to automatically start upon system start-up?
The file exists, but I still need to start Studio manually in order for the remote app to see it.
Also, when I play back a file from Qobuz (still haven’t worked out how to mount my local music library drive), the age-old UPnP problem of incompatability with my Auralic streamer is still apparent.
Not entirely sure if I’ll make the best use of this Linux build, but wish Audirvana all the best with it :+1:
It won’t solve all problems with the Auralic (though I did notice at least one Windows bug I reported didn’t exist with the Linux app), but here’s how to start on every bootup automatically:
sudo ./setAsService.sh enable
(Do this in a terminal opened in the same folder as setAsService.sh .)
The directory i$HOME/.config/audirvana/ s empty after starting audirvana.
If you can find the content of the file…
BTW, when you are attempting to first run Audirvana, have you stopped Roonserver and hqplayerd?
I have success with installing on RPI Zero 2W, but it doesn’t play anything more than 96khz because of insufficient ram. Whole rpi crashing. Even i can’t log into ssh.
On RPI 4 2GB working fine and plays everything.
@hifi25nl for example, the configuration file for Audirvana in my Docker container can be found here (I’ve removed sensitive values from the file):
# cat /root/.config/audirvana/audirvana-studio.ini
EulaAccepted = 1
WindowSavedPrefs =
AzureRefreshToken =
PairedRemoteControls = {"":"","":":::"}
LastUpdateCheck =
PreferredAudioDeviceType = 0
PreferredAudioDeviceUID =
PreferredAudioDeviceModelUID =
PreferredAudioDeviceName =
DSDUpsamplingTarget =
On a GNU/Linux desktop, the configuration file will likely be in /home/<USER>/.config/audirvana/audirvana-studio.ini.
If the configuration audirvana-studio.ini file isn’t getting created or EulaAccepted = 0, then that would explain why you see the INFO message (it isn’t an error).
If you are running a Docker container without a named volume or bind mounting a local directory to preserve the configuration audirvana-studio.ini file, then you will see this everytime as well.
There are a variety of circumstances that could cause this, but this issue is always that the audirvanaStudio binary did not find audirvana-studio.ini or the EulaAccepted variable is set to 0 in the config file.
I hope that’s helpful for you.
Hi @Jud
When I posted my query last night, I just KNEW you’d provide the solution :rofl: :rofl:
Many thanks mate, worked a treat :+1:
H @hifi25nl
in despite I get this message "EULA not accepted yet, showing it ", Audirvana Studio is working and I can connect Audirvana remote app without problem on Audiolinux.
But after EULA message I get this one:
2024-04-15 11:11:51.169 [info]: RemoteServer: Server started and advertised on port 40523
Do you get this second message in your case ?
I’ve used debtap in my case.
