Audirvana Studio 1.13.2 (11302)
macOS Version 12.4 (Build 21F79) with 32GB physical RAM
Connected account of : Thomas Wxxxxxxxxxxxxxxx
Sync list: 2 folders
AUTO: /Volumes/music/Flac Server
AUTO: /Volumes/music/MQA Server
Library database path: /Users/tom/Music/Audirvana Studio Database/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 55069
CoreAudio audio path, buffer I/O frame size: 4096
Max. memory for audio buffers: 4086MB
APPLE INC. IMAC PRO-LAUTSPRECHER
Model UID:Speaker
UID:BuiltInSpeakerDevice
Hog Mode is on
ID 0x54 iMac Pro-Lautsprecher
Model Name: Apple Inc. iMac Pro-Lautsprecher
Model UID: Speaker
UID: BuiltInSpeakerDevice
Stream ID 0x55 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x54 iMac Pro-Lautsprecher Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. iMac Pro-Lautsprecher
Device #1: ID 0x2c Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0 Model Name: ma++ ingalls for Cycling '74 Soundflower (2ch)
UPnP devices found : 4
Device #0: ID 0x0 WDTV UID: uuid:0e4eeebf-0090-a9f8-2716-5363475bd763 Location: http://192.168.0.41:10184/
Device #1: ID 0x0 Pioneer N-70AE EBF17C UID: uuid:xxxxxx-007c-f1FF-b000-0009b0ebf17c Location: http://192.168.0.22:8888/upnp_descriptor_0
Device #2: ID 0x0 Pioneer VSX-S520D ECFDD4 UID: uuid:xxxxxx-00d4-fdBB-b000-0009b0ecfdd4 Location: http://192.168.0.26:8888/upnp_descriptor_0
Device #3: ID 0x0 Sensia 200D Connect UID: uuid:xxxxxxx-cb6a-4857-b891-0019f581aa00 Location: http://192.168.0.20:42228/93b2abac-cb6a-4857-b891-0019f581aa00.xml
