In search view when an album has been chosen the “Play” and “Shuffle” buttons have now been removed - before they existed, but didn’t work.
Not yet solved
In search view when an artist has been chosen the “Play” and “Shuffle” buttons have now been removed - before they existed, but didn’t work.
In search view clicking on “Show all”, all albums / artists / tracks are shown correctly, but the “Play” and “Shuffle” buttons miss to play all results. Chosing the componist, the “Play” and “Shuffle” buttons exist, but don’t work. It’s not possible to play the selected items.
In search view clicking on “Show all” tracks, they are shown correctly. Clicking the play button on the left of track, replay starts. Clicking the play button of any track after that, leads to a reduplication of the found results.
Choosing an artist in artist view shows the albums belonging to this artist: “Play” and “Shuffle” buttons don’t work. Clicking on show all, “Play” and “Shuffle” buttons are removed. It’s the same behaviour, when you start in the artist view and then choose an artist.
Changing in a playlist from track view to album view shows extremly little album icons or sometimes a black screen. In the view of the whole library it works correctly.
Cmd L: Should show the played track. It works now as long as you are in the view of the whole library or in the playlist the replayed tracks belongs to. If you are in an other playlist than the replayed track belongs to, it still doesn’t work.
The backward / forward button on top in the menu: If you choose something of your search results and than want to go back to the search results, a black screen is shown.
Filter panel for intelligent playlists: Changing for example from album to genre in the 1st column removes the value in the 3rd column. This is very unpractical: please leave the value in the 3rd column and recompute the search with the changed value.
Little layout quirk in the banner of albums: After the hyphen between composer and artist a space is missing.
Shuffle means, that a list is played in a random way. AS always starts with the same track. Realy random would be, if also the 1st track would be randomly computed.
Dropdown list of filter criteria is not in alphabetical order. Please sort it.
To make the work in AS easier, it would be helpfull, if the shortcut ESC would be asigned to all “Cancel” commands, ENTER to all “OK” commands and Cmd-W for the closing of windows.
Little translation correction for the german version in the info panel: “Album art” is better translated with “Cover” than with “Kunstwerk” (even if it is the English expression, we understand it )
AS becomes better - thank you. In my opinion the “Play” and “Shuffle” buttons should exist and work in every sort of view - that’s a basic function of a music app. Please fix this problem soon.
Fixed
Not yet fixed
The backward / forward button on top in the menu: If you choose something of your search results and than want to go back to the search results, a black screen is shown. Additional problems see here: Back Button problems update 1.9.0
Cmd-A to choose all albums or choosing some / all albums with draging the mouse with held left mouse button over albums is not possible.
In search view clicking on “Show all”, all albums / artists / tracks / composers are shown, but the “Play” and “Shuffle” buttons miss to play all results. It’s not possible to play the selected items. Buttons have been removed - before they existed, but didn’t work.
In search view clicking on “Show all” tracks, they are shown correctly. Clicking the play button on the album cover, replay starts. Clicking the play button of any track after that, leads to a reduplication of the found results.
Choosing an artist in artist view shows the albums belonging to this artist: The “Play” and "Shuffle"buttons work. Clicking on the “Play” button, when shuffle is activated, doesn’t remove the shuffle function but should.
Opening AS shows a black screen, if you don’t have any favorites.
The backward / forward button on top in the menu: If you choose something of your search results and then want to go back to the search results, a black screen is shown. Additional problems see here: Back Button problems update 1.9.0
Filter panel for intelligent playlists: Changing for example from album to genre in the 1st column removes the value in the 3rd column. This is very unpractical: please leave the value in the 3rd column and recompute the search with the changed term of the 1st column.
The "Play"and “Shuffle” buttons in playlist view should be in the top banner, so we can always reach them and don’t have to scroll up. In the playlist window the active playlist should be purple.
The purple (i.e. active) color of the chosen playlist gets lost as soon as you open an album in this playlist.
I changed to Audirvana Origin and have a look now in Version 1.06 Fixed
In search view clicking on “Show all”, all albums / artists / tracks / composers are shown, but the “Play” and “Shuffle” buttons miss to play all results. It’s not possible to play the selected items. Buttons have been removed - before they existed, but didn’t work. Thank you
In search view clicking on “Show all” tracks, they are shown correctly. Clicking the play button on the album cover, replay starts. Clicking the play button of any track after that, leads to a reduplication of the found results. Thank you
Changing in a playlist from track view to album view shows extremly little album icons or sometimes a black screen. In the view of the whole library it works correctly. Thank you
The purple (i.e. active) color of the chosen playlist gets lost as soon as you open an album in this playlist. Thank you
Not yet fixed
In search view clicking on “Show all” tracks, they are shown correctly. “Play” and “Shuffle” buttons miss to play all results. Please add these.
Clicking on the “Play” button on top of a list, doesn’t remove the shuffle function, when shuffle is activated, but should do that.
Starting AO shows a black screen, if you don’t have any favorites. I see 3 options for amelioration: On start AO shows the album view of the whole library or better shows the last screen before quitting AO or best give the option to choose in preferences, where AO starts.
Cmd L: Should show the played track. It works now as long as you are in the view of the whole library or in the playlist the replayed track belongs to. If you are in an other playlist than the replayed track belongs to, it still doesn’t work.
The backward / forward button on top in the menu: If you choose something of your search results and then want to go back to the search results, a black screen is shown. Example Mozart, show all composers is correctly displayed, hitting the back button shows:
“mozart” is still shown in the search field, but it is not possible to search for it again unless you change “mozart”. This is not intuitive.
The "Play"and “Shuffle” buttons in playlist view should be in the top banner or fixed below the top banner, so we can always reach them and don’t have to scroll up.
As mentioned by many users the floating playlist window destroys the nice look of the GUI. The solution of having the playlists in the sidebar as before in A 3.5 would look nicer
Shuffle means, that a list is played in a random way. AS always starts with the first track. Realy random would be, if also the 1st track would be randomly computed.
To make the work in AO easier, it would be helpfull, if the shortcut ESC would be asigned to all “Cancel” commands, ENTER to all “OK” commands and Cmd-W for the closing of windows.
Little translation correction for the german version in the info panel: “Album art” is better translated with “Cover” than with “Kunstwerk” (even if this is the English expression, we understand it )
New UI Problem
Opening the search results for all tracks shows the list. Clicking on the artist should show all albums of this artist. Sometimes it works, sometimes AO shows a black screen. Composers work correctly. @Antoine: Can you reproduce that on your side?
When I play the track, Audirvana displays the correct image of the song . Pls see bottom LHS.
However in the Title, all songs has the same pic. How can I fix this?
PS: My first post with my questions, went into your Spam filter
Hi
Sorry for the delay of my answer. I was some days away.
Do I understand you correctly? Your albums have different album art and Audirvana shows always the same pic in the tracklist? This seems very uncommon to me.
Can you please check in the finder or with an ID3 tagging app, if your albums have different albumart.
How are they sorted on your harddrive: Every album in its own folder or all tracks in one folder?
From the pic posted above, I am playing the purple line. In the bottom you can see album art of the song , however in the tracklist it shows the same image.
When I click a different song, it shows the correct album art on bottom RHS corner, just on the tracklist, they all display same album art.
Yes, I could see that.
I don’t know, how A retrieves album art. Maybe it depends on how your files are located. In my case I sort them in folders that way: Music > Artists > Albums > Tracks and it works fine. @Antoine: Do you have any explanations for this problem?
Me also.
SSD/Music/Artists/Albums, the tracks sort themselves… Or should I say, are sorted when downloaded / ripped, provided they have track number tags!
Solved issues Filter-Editor
2nd button on top German version: On mouse over the correct text is shown „Mindestens eine Regel muss gelten“. Clicking it shows a wrong text: „Jedes Kriterium ist wahr“
Album view
Little mistake: If the artists name contains a period, A doesn’t show the full name.
Miscellaneous
Shuffle now plays now really randomly
If you have many albums of an artist, you have to choose at first “Show all” to see all of them. Why not show all of them? This would save 1 click.
Still existing issues Filter-Editor
Miscellaneous
In search view clicking on “Show all” tracks, they are shown correctly. “Play” and “Shuffle” buttons to play all results do not exist on top of this list. Please add these.
Solved: “mozart” is still shown in the search field, but it is not possible to search for it again unless you change “mozart”. This is not intuitive.
To make the work in A easier, it would be helpfull, if the shortcut ESC would be asigned to all “Cancel” commands, ENTER to all “OK” commands and Cmd-W for the closing of windows.
Artists and composers are mixed under “Artists” in the sidebar. Please consider to add the category “Composers” and separate them.
Updated to A Origin 2.5.9 (20509). A year after my last review I was curious, how Audirvana evolved its UI over time.
Filter-Editor: Changing for example from album to genre in the 1st column removes the value in the 3rd column. This is very unpractical: please leave the value in the 3rd column.
In search view clicking on “Show all” tracks, they are shown correctly. “Play” and “Shuffle” buttons to play all results do not exist on top of this list. Please add these to be able to play this list.
The backward / forward button on top in the search menu: If you choose something of your search results and then want to go back to the search results, a black screen is shown. Correct would be the first screen of my search.
Sort order can only be defined globaly. It should be possible to define it for every playlist individualy.
Little translation corrections for the german version:
Info panel “Album art” is better translated with “Cover” than with “Kunstwerk” (even if this is the English expression, we understand it )
Dialog box “Duplicates in playlist”: The left button is “Rückgängig machen”. Better would be “Abbrechen” because Rückgängig machen means, that you already added the titel to the list and want to remove it now. Actuelly you don’t want to add the tittle.
